Originally Posted by ecomodded
Having a Propane fireplace as I do with 100# tanks will keep you warm threw the power lapse, as would a wood stove etc.
I'm fortunate that "heat" is never a problem when the power goes out around here. It's usually 92°F with a feels like of 102°F during the day, and gets down to a low of 82°-84°F at night with humidity in the 70-95% range.
Now that I have the Norcold 40qt and 60qt compressor driven 12v/120v coolers, I've got some options for keeping things cold without running the generator quite so much.
If it looks like it might be awhile, there's always the 2kW inverter I picked up off craigslist for free, or the collection of smaller ones I have lying around.
The cell phones can recharge off the 20W PV setup.
Based on the measurements from my TED 1001, I could technically run my central air off the 5,500W generator, but finding ~10 gallons of gas each day gets to be challenging and expensive.
