Old 03-19-14, 05:48 PM   #4
Originally Posted by ecomodded View Post
I like that its palm sized, looks easy to hold steady,it will be possible to refill it using an adapter for the 220g bayonet mount butane canisters commonly sold for $2-2.50 a can in hardware stores. A few days ago I saw online, a refill adapter that provides the cheap 220g butane can with a lighter refill end on it.
I had just bought an adapter so I can use the 220g butane canisters with my backpackers lightweight jet stove (weighs just 100 grams), for a 70% savings in fuel costs/expense. At the same time I bought another propane butane adapter so I can mix my own 70-30 butane propane for my colder weather camp fuel.
I wonder if the little torch would work with 100% propane.?.
Is there a fill adapter that will allow using a 14-16 ounce propane tank, to fill up the micro torch?
