Originally Posted by pinballlooking
It was cold here also about 2 am it got down in the teens I turned the LG units off. They were still putting out some heat but at that point gas is cheaper to heat with.
The Gree unit as usual did great I left it on all night. The rest of the house we used our natural gas heat. The room that has the Gree mini split has a big return in the same room so it would help the rest of the house some.
It is now up to 48 deg and the Mini splits are making all the heat. Solar is cranking out 9.3KWH much better than the last couple days.
You're making that Gree sound better and better!
Really good solar here today. My panels over-perform when it's below 20F.
