Yep, thermostat is in the living room. It's working ok until I can get around to a differential. Got down to 17F last night. Good thing I moved the hide-a-bed couch out by the stove. I slept there and threw some firewood into the stove anytime I woke up to a chill. Thermostat is set to 67 when I'm home 62 when I'm sleeping and 60 when I'm gone. The fan is cycling on and off instead of running full time. You'd think I had a regular furnace going if you walked in. I'm worried that it may be quite cold when I get home tonight. I've been making plans on how to move more/hotter air. Right now I have about 84 degrees going in the return and 73 coming out in the living room. I'll add some information here when I start building the differential thermostat. I may put multiple units placed strategically through the house if it doesn't prove too difficult.
