I'm hoping you mean
these folks and NOT
these folks?
Interesting that California requires nominal 1kW system to use the CEC/PTC numbers rather than the 'peak' 1020W claimed by the non-California system. I hope you used the corrected values when calculating your payback?
I'm not familiar with the company or your siting conditions, but the first two questions to ask are always the same: where are you located, and how much electricity does your household use every day?
Eleven years RoI after incentives is about right for grid-tied PV in a 4-5 hr/day location, if your utility pays or credits at retail. What are the net metering laws in your state, and how cooperative is your utility company? Is the supplied GT inverter on their list of acceptable hardware?
If it were my money, I would buy name-brand panels. Some of the Chinese PV is good, some is outright dangerous: I've seen photos of a roof fire caused by manifestly defective Chinese panels. Consider
this Sanyo-based system from the very reputable Affordable Solar company: Unlike the Power-Save system, it has a lot of the sneaky-expensive
balance of systems included, like lightning protection, disconnects, cabling, etc. Most importantly, its inverter is rated for 2000W so you could add panels in the future without buying a new inverter. I'd lean toward something like this kit, then add a panel or two. Bet you come out ahead.
