Originally Posted by MN Renovator
Back to your temperature rise, this sounds like you have an inadequate ductwork issue, if there is enough restriction in your ductwork
Or leaks! Let's not forget leaks! What domestic HVAC contractor uses enough duct mastic, even in these enlightened days? Certainly not the boobs I deal with day to day.
Also I think you're spot on about air sealing! Even if you have no insulation at all (and I'm being quite serious here) you will do well with kick *** air sealing. Something on the order of 1 ACH @ 50 or so.
