Recycling old space heaters
If you have an old space heater with a thermostat, that not being used anymore, it might be useful to prevent freeze-up in unheated rooms.
We got our first sufficient snow last night! http://i46.photobucket.com/albums/f1...r/NCL/A007.jpg Since we started using a Sanyo ASHP, the den isn't heated at night. Only a small amount of heat from the main living area is allowed to escape into the den. The room has a LOT of glass and it's been going down into the low 50s this past week. So, I set the space heater for 47 degrees, Just in case! |
