Forum: Conservation
02-22-17, 05:56 PM
Earth Tubes Get a Winning Review...
http://ecorenovator.org/forum/attachment.php?attachmentid=7622&stc=1&d=1487807695
Earth Tubes sound like a great idea, and they are. But there have been a lot of stories about their...
Forum: Renovations & New Construction
10-17-15, 06:24 PM
Forum: Conservation
05-30-15, 06:57 AM
Forum: Conservation
05-29-15, 05:54 PM
I posted pics of ground tube network I plan to...
I posted pics of ground tube network I plan to use to temper subzero fresh air to DIY exchanger(in Eco-build thread). Three 100' 6" sewer pipes linked together at foundation. Each run has a nylon...
Forum: Conservation
05-28-15, 10:42 PM
Years ago I was renovating a house (without AC)...
Years ago I was renovating a house (without AC) located on a hill. I used corrugated metal pipe - two runs of 8" I think it was. The pipe went out the basement wall, across the back yard, and exited...
09-24-14, 06:01 AM
Actually it is best as a cold supply to the...
Actually it is best as a cold supply to the shower. Then the hot can be balanced down. Or...you could have it feed the cylinder, either/or.
Yes, our drains are all plastic now but commercial or...
09-24-14, 05:24 AM
09-06-14, 03:52 PM
I had a very similar heat pump that was also...
I had a very similar heat pump that was also designed for heating water.
I don't know about yours, but the one I had was designed for indoor use only, and it had no crank case heater or anything....
07-09-14, 03:41 PM
Forum: Forum News & Feedback
01-23-14, 01:09 PM
12-16-13, 11:44 AM
The correct answer here is:
Not everyone...
Not everyone wants to invest the time, labor, and money to do the best job possible. There is usually a point where the return on investment diminishes beyond design...
Forum: Conservation
07-12-12, 12:02 PM
Thanks, gentlemen. I got some pictures together...
Thanks, gentlemen. I got some pictures together that you can look at here (https://plus.google.com/photos/112965711974935529231/albums/5764307724644978305). Water comes in from the left, goes through...
Forum: Conservation
01-07-12, 06:07 PM
