Forum: Renovations & New Construction
05-24-17, 09:17 AM
05-24-17, 07:48 AM
Ben,
I use the brass lug nuts to connect...
Ben,
I use the brass lug nuts to connect the wires togtether. I also put on anticorission paste before i put wires in. Then I wrap with 3-M tape and do 30-40 wraps. A big ball that I want to...
Forum: The Billiards Room
05-20-17, 08:05 AM
Forum: Appliances & Gadgets
05-16-17, 11:22 AM
05-16-17, 09:51 AM
I have literally placed thousands of wooden...
I have literally placed thousands of wooden posts. Treated is essential, but know there are different treatment levels.
The key is to have drainage below the post. I like a minimum of a 30 inch...
05-08-17, 09:28 AM
I got two more pieces of racking up.
I was...
I was also able to borrow an auto-retractor fall protection device. I'll be using that for the rest of the install - the metal roof is FAR more slippery than...
04-27-17, 11:27 AM
Forum: Solar Power
04-23-17, 04:56 PM
02-25-17, 09:19 AM
Forum: Conservation
02-22-17, 05:56 PM
Earth Tubes Get a Winning Review...
http://ecorenovator.org/forum/attachment.php?attachmentid=7622&stc=1&d=1487807695
Earth Tubes sound like a great idea, and they are. But there have been a lot of stories about their...
12-21-16, 02:13 PM
Garage Door Opener Won't Open or Close
My garage door quit working correctly. I could hear the motor running but it does not move the door anymore. It is 16 years old.
I released the door from the opener it works fine manually.
I...
12-03-16, 06:53 AM
Forum: Other Improvements
12-02-16, 03:18 PM
11-26-16, 07:31 PM
I ended up buying 12 fixtures. I went to the...
I ended up buying 12 fixtures. I went to the closest store, and they were all completely sold out. Well, they were sort of a Black Friday special....
I used my smart phone to check out the store's...
11-13-16, 11:00 AM
Building a 100 Year Refrigerator
Haven't been on the forum in some time; I have been busy. Began a project in June to construct a modular, long lasting refrigerator. It has gone through many iterations, and there are many more to...
Forum: Lawn and Garden
11-06-16, 11:28 PM
Always store your pH pen with electrode storage...
Always store your pH pen with electrode storage solution in the cap. Make sure it never dries out. Most pH pens have a 3M or 4M KCl reference solution inside the electrode. That's what the storage...
Forum: Solar Power
10-16-16, 04:38 PM
Roostre,
I am assuming this is a 10 panel x...
Roostre,
I am assuming this is a 10 panel x 4 row system?
Buy your own ground wire locally. Call Renvu, speak to a sales rep and ask for a first time discount. I am not sure why you need 42...
04-14-16, 11:38 AM
@papitohead it has been a fun ride.
Here is a...
Here is a lunch provided the Aquaponics garden.
http://ecorenovator.org/forum/attachment.php?attachmentid=6861&stc=1&d=1460651953
Ok this is what it looked...
Forum: Solar Heating
02-10-16, 08:53 AM
01-22-16, 01:15 PM
I don't really think so. In order to properly...
I don't really think so. In order to properly insulate the containers you either loose most your inside space or you have to spend a lot of money cutting and welding to make them usable. Plus now the...
07-15-15, 09:52 PM
02-04-15, 12:20 PM
Forum: Tools
11-21-14, 12:02 PM
Rent-a-Flir (post #3)
Continuing on...
http://ecorenovator.org/forum/attachment.php?attachmentid=4793&stc=1&d=1416587509
This image is from the back of my house, where a remodel of my back room is taking place...
11-02-14, 10:51 AM
10-20-14, 02:28 PM
HP COP vs NG boiler $ Balance point
I want my Heating System controller (Arduino) to be able to automatically switch between HP and NG boiler, based on $ calculations.
Code must calculate the HP COP vs. Natural Gas $ Balance Point....
