Forum: Appliances & Gadgets
11-06-13, 10:31 AM
11-06-13, 10:29 AM
If you do a search, of EcoRenovator, you will...
If you do a search, of EcoRenovator, you will find a huge discussion regarding this very subject.
As for myself, I think that clothes dryers are an abomination... in that they beat our clothes to...
Forum: Conservation
11-06-13, 10:16 AM
Yeah, that could definitely help. :) If that...
Yeah, that could definitely help. :) If that doesn't get you all the way there, I would definitely give the timer a shot though. You should be able to REALLY cut down on the power usage with one....
Forum: Lighting
08-07-13, 11:00 AM
Can you cite that story?
Not saying you're...
Not saying you're making it up, but as an employee of the largest haz-waste company in North America, I find that price to be astronomical. :eek:
A $30 clean up kit,...
05-09-13, 08:55 AM
I used a Honeywell VisionPro IAQ 7 day...
I used a Honeywell VisionPro IAQ 7 day programmable on my split system heat pump with propane backup. This T-stat solved numerous problems for me. I installed the outside temp sensor, get rid of the...
04-12-13, 08:50 AM
Well, obviously the fact that you can't do...
Well, obviously the fact that you can't do set-back is what is wrong with the mechanical one, what part of "set-back" do they not understand?
All the stuff that SH said is right, with the addition...
04-11-13, 01:46 PM
Razor,
Your choice of heat pump thermostat...
Razor,
Your choice of heat pump thermostat is a choice of air to air or geothermal heat pumps. Then there is the need for two stages as many heat pumps have two stages. Almost all thermostats...
Forum: Introductions
04-01-13, 11:51 PM
04-01-13, 08:02 AM
Forum: Lighting
06-07-12, 07:52 AM
Joining the thread. I'm interested in how the...
Joining the thread. I'm interested in how the LED's compare, also. Mostly as replacements for the little halogen spots on the range hood and for our ceiling fan. The fan wobbles on higher speeds...
Forum: Conservation
01-08-12, 07:48 PM
Does bubble-wrap work for insulating windows?
For $15, I bought a roll of 24" wide roll of bubble wrap, enough for three or four windows (I only wanted to do the lower windows).
Forum: Conservation
03-04-10, 09:58 AM
Laminar Flow & Turbulent Flow
In Fluid Mechanics, there is the issue of laminar vs. turbulent flow.
http://ecorenovator.org/forum/attachment.php?attachmentid=622&stc=1&d=1267715963
This graphic illustrates a couple of...
