Search Forums
Search Results
User Name
Remember Me?
Password
Blog
60+ Home Energy Saving Tips
Recent Posts
Search
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 9 of 9
Search took
0.00
seconds.
Search:
Posts Made By:
bernard
Forum:
Solar Heating
11-05-15, 09:18 AM
5
Daily regime of solar controller during vacations
4,958
Posted By
The controller should have logic build into it so...
The controller should have logic build into it so that your tank temperatures do not exceed a certain temperature. The reason for this is that the coolant in the lines will degrade at higher...
Forum:
Solar Heating
10-14-15, 11:15 AM
19
How much energy to heat 100 liters of water?
12,427
Posted By
1kw of electricity equals 1kw of heat. Its a...
1kw of electricity equals 1kw of heat. Its a direct relationship.
Forum:
Solar Heating
10-14-15, 08:11 AM
19
12,427
Posted By
Those two can be directly compared. They are...
Those two can be directly compared. They are essentially defined amounts of heat energy. Btu's are also a raw amount of heat. As with all physical systems, the heat you put in is greater than what...
Forum:
Solar Heating
10-13-15, 02:02 PM
19
12,427
Posted By
bmxeroh
A watt is a watt. They are not two different...
A watt is a watt. They are not two different types of values to be compared. Simply put, it takes more power input to heat with gas than with electric BECAUSE some of the input is lost due to the...
Forum:
Solar Heating
10-13-15, 08:03 AM
19
12,427
Posted By
stevehull
With different fuels, the number of BTUs,...
With different fuels, the number of BTUs, calories or other energy units would be exactly the same to heat a specific quantity of water up by a number of specific degrees.
However, combusted fuels...
Forum:
Solar Heating
09-14-15, 08:28 PM
21
Overall piping length in swh systems
14,253
Posted By
stevehull
Let me start again. Assume it is 10 meters...
Let me start again.
Assume it is 10 meters from the lowest level (where the storage tank is perhaps in the basement of the home) all the way up to the roof. This might be two stories total. This...
Forum:
Solar Heating
09-14-15, 04:35 PM
21
14,253
Posted By
stevehull
If you have a straight shot from the basement to...
If you have a straight shot from the basement to the roof, then each story only adds ~ 5 meters or so for each run (10 meters for the input and output; two pipes). Also depends on how tall each...
Forum:
Solar Heating
09-14-15, 04:06 PM
21
14,253
Posted By
stevehull
Pipe resistance (and thus the size of the pump)...
Pipe resistance (and thus the size of the pump) is HIGHLY dependent on the diameter (radius to the 4'th power). The length is only a minor contributor (unless you are talking of hundreds of meters...
Forum:
Solar Heating
09-14-15, 03:31 PM
21
14,253
Posted By
stevehull
If you do a drain back system, you need a larger...
If you do a drain back system, you need a larger and more powerful pump compared to a closed loop. In the closed loop, you only have to overcome pipe flow resistance and not gravity (as with the...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forum News & Feedback
Introductions
Improvements
Conservation
Lawn and Garden
Appliances & Gadgets
Tools
Geothermal & Heat Pumps
Lighting
Renovations & New Construction
Solar Heating
Solar Power
Wind Power
Biofuels
Energy Storage
Other Improvements
Product Reviews
EcoRenovator Blog Discussion
Off Topic
The Billiards Room
For Sale / Trade / Wanted / Web Finds
12:04 PM
-- Green
---- Test Green
-- Blue VB
Contact Us
EcoRenovator.org
Archive
Top
Ad Management by
RedTyger
Inactive Reminders By
Icora
Web Design
