Search Forums
Search Results
User Name
Remember Me?
Password
Blog
60+ Home Energy Saving Tips
Recent Posts
Search
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 5 of 5
Search took
0.00
seconds.
Search:
Posts Made By:
r290r600
Forum:
Geothermal & Heat Pumps
03-19-14, 06:13 PM
13
pressure testing mini split wit argon instead of nitrogen
20,252
Posted By
It probably got cold overnight. If you had a...
It probably got cold overnight. If you had a leak, the pressure definitely would have dropped much more (like 20 PSI per hour). You should be OK to proceed.
Make sure and read the directions with...
Forum:
12-23-13, 09:33 AM
32
R290 undercharge in 1 ton cap tube split sytem heat pump?
25,186
Posted By
mejunkhound
+1 plus, if you used bbq propane for R290,...
+1
plus, if you used bbq propane for R290, and the 410 system did have a cap tube, just the 10 ppm of water in bbq propane may be enough to freeze a slug of ice in the cap tube.
TXV will...
Forum:
12-23-13, 01:18 AM
32
25,186
Posted By
You can try to balance your system by adding...
You can try to balance your system by adding R290, but with a metering device made for R410, the system will never run at high efficiency unless you recharge it with R410a. The engineers put an...
Forum:
12-23-13, 01:10 AM
32
25,186
Posted By
I think that if you make major changes to the...
I think that if you make major changes to the volume of the system, it's just too complicated to charge by weight.
It's a lot nicer if you have a hi-side Schrader valve AND a lo-side Schrader...
Forum:
12-22-13, 10:47 PM
32
25,186
Posted By
NiHaoMike
Add a sight glass and a R22 TXV.
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forum News & Feedback
Introductions
Improvements
Conservation
Lawn and Garden
Appliances & Gadgets
Tools
Lighting
Renovations & New Construction
Solar Heating
Solar Power
Wind Power
Biofuels
Energy Storage
Other Improvements
Product Reviews
EcoRenovator Blog Discussion
Off Topic
The Billiards Room
For Sale / Trade / Wanted / Web Finds
05:29 AM
-- Green
---- Test Green
-- Blue VB
Contact Us
EcoRenovator.org
Archive
Top
Ad Management by
RedTyger
Inactive Reminders By
Icora
Web Design
