03-04-14, 06:02 PM
Forum: Solar Power
03-04-14, 04:31 PM
The Kw meter will help the calculations a lot...
The Kw meter will help the calculations a lot better and easier for figureing battery banks and panels. Found out last year. Before the insulation my place i pulled 15 kws a day for the whole house....
03-04-14, 03:46 PM
How to make Horizontal loop holes
Went out the other day had a idea that could help out some of the people who have rock down 15 or so ft where they couldnt drill there own verticle holes. So . I dug 2 small holes about 4 or 5 ft...
02-28-14, 04:48 PM
02-28-14, 10:28 AM
Forum: Solar Power
02-24-14, 10:43 PM
Don't do this! You can get away with losing...
Don't do this! You can get away with losing power to your fridge for 12 hours once in awhile, such as when you come across a power outage but they aren't nearly as well insulated as they need to be...
Forum: Solar Power
01-16-14, 03:27 PM
Voltage Drop Calculator...
Voltage Drop Calculator (http://www.windsun.com/Hardware/Voltage_Calc.htm)
Heres a link that you may find helpful on voltage drops.
Unless your dead set and already have the pannels i would run...
Forum: Solar Power
01-14-14, 07:54 AM
Forum: Solar Power
01-13-14, 06:57 PM
