Go Back   EcoRenovator > Search Forums
Showing results 1 to 10 of 10
Search took 0.01 seconds.
Search: Posts Made By: mechanic
Forum: Appliances & Gadgets 05-06-20, 11:02 AM
Posted By BillG
If you know someone who does commercial controls...
If you know someone who does commercial controls and has access to the Distech brand, their ECY-TU controller with separate sensors can do that. Their programming tool is free and elegant.
Another...
Forum: Appliances & Gadgets 05-06-20, 06:57 AM
Posted By jluther23
This may be a little late, if you already have a...
This may be a little late, if you already have a solution. If you are in to DIY projects you need to look into software called Home Assistant. I use it with a raspberry pi to monitor temperatures...
Forum: Appliances & Gadgets 05-04-20, 07:32 PM
Posted By H16bill
Pretty easy to build a WiFi thermostat based on...
Pretty easy to build a WiFi thermostat based on the wemos d1 processor. Then you can do any kind of logging you want. I was considering doing this for our vacation house since the kitchen...
Forum: Appliances & Gadgets 04-14-20, 10:46 PM
Posted By where2
When I got to thinking about this question, it...
When I got to thinking about this question, it dawned on me: why not make a man in the middle device? Sense the high versus low condition on the output leads to the thermostat wire, and log high (or...
Forum: Appliances & Gadgets 04-10-20, 03:58 PM
Posted By MN Renovator
I considered getting an Ecobee for the data...
I considered getting an Ecobee for the data logging function but was put off by the price. My current thermostat has an 'energy' button that counts the run-time based on when it is calling for heat...
Forum: Appliances & Gadgets 04-10-20, 02:52 PM
Posted By Daox
Great question. I have a very simple wifi...
Great question. I have a very simple wifi thermostat without any datalogging. It would be great to have this feature.
Forum: Geothermal & Heat Pumps 07-15-16, 02:59 AM
Posted By STM
Huge refrigerant chart
May be of use to someone. PDF.
http://detector-cooling.web.cern.ch/Detector-Cooling/data/Refr.ptchart2.pdf
Forum: The Billiards Room 01-05-16, 02:13 PM
Posted By Daox
Most popular threads of 2015!
What generated the most hubbub in 2015? Lots of interesting things! Check it out below. :thumbup:
1) New Aquaponics system build (http://ecorenovator.org/forum/showthread.php?t=4334)
Forum: Appliances & Gadgets 10-21-15, 01:22 AM
Posted By AC_Hacker
Yes, you're right about that. And what with...
Yes, you're right about that. And what with winter coming on up in your neck of the woods, it's a perfect time to hunker down and learn a new skill.
I can't think of a better book that this...
Forum: Solar Heating 02-26-15, 04:01 AM
Posted By house4u
Hot water solar system of house4u (Viktor)
Hi, my name is Viktor. I have made my heating solar system by myself. It consist of 10 collectors with total area about 18.2m2, Heat storage 1600L and DHW boiler 250L.
Here is my online monitor...
