11-26-20, 06:21 PM
07-15-18, 05:02 PM
Just checked the meter, the hours had run out...
Just checked the meter, the hours had run out past 9999, so I looked back at the last date of when I finished the unit. The unit continued to measure kWh.
3 years or 1100 days. And 2000 kWh comes...
Forum: Solar Power
03-25-18, 08:00 AM
Vanadium flow battery
This popped up on my facebook. Look highly promising thought I would share and see yalls thoughts.
05-12-17, 08:33 PM
Forum: Renovations & New Construction
09-11-16, 03:25 PM
MEMPHIS builds a house
So I never thought I would say this but we now have plans on moving, the current location/house/stress is not what we want. So we have plans on moving to another county (this one is getting way to...
Forum: Solar Power
07-31-16, 12:10 PM
I am googling the terms you mentioned. I have...
I am googling the terms you mentioned. I have access to a multitude of parts. And this really seems like an awesome idea. I am all for building and testing a unit, and tweeking the needed solution. A...
07-21-16, 09:00 PM
07-14-16, 08:28 PM
This weekend is pretty full for me. But my job...
This weekend is pretty full for me. But my job has me traveling north MS a lot. Where are you in MS? I might be able to get it closer to you if I have a job near by. I've got a dehumidifier with your...
07-13-16, 06:41 PM
Howdy fellow Mississippian!
I happen to have...
I happen to have some perfectly sized R22 compressors laying around that I wouldn't mind letting you have. If you are close enough to drive, shoot me a pm with your...
Forum: Solar Power
06-15-16, 06:21 AM
06-14-16, 06:33 PM
06-13-16, 10:05 PM
06-07-16, 08:53 PM
06-07-16, 07:14 AM
Forum: Conservation
04-23-16, 05:52 PM
02-12-16, 07:55 PM
Doax you mind changing this thread title to...
Doax you mind changing this thread title to "MEMPHIS's Home Insulation Project"?
So I was able to use 6 cans of spray foam and some insulation board to patch the holes in the eves of the house.
Forum: Other Improvements
02-10-16, 08:04 PM
WILL DO!!
So the big orange big box store...
WILL DO!!
So the big orange big box store had some 8" duct on sell today, SO that is what I got!!
I used some left over duct from another project as well, total cost today was $20. Total cost...
Forum: Solar Heating
02-08-16, 07:47 PM
02-07-16, 02:59 PM
Forum: Lawn and Garden
02-04-16, 08:28 AM
02-03-16, 08:51 PM
I finally got my heater up and working. I did 3...
I finally got my heater up and working. I did 3 layers of bug screen on mine.
Temp in box was 175F without air flow and I got 125F at the vent in the house at about 400cfm. I write up details when...
01-27-16, 08:42 PM
01-24-16, 03:29 PM
01-24-16, 01:01 PM
01-22-16, 01:15 PM
I don't really think so. In order to properly...
I don't really think so. In order to properly insulate the containers you either loose most your inside space or you have to spend a lot of money cutting and welding to make them usable. Plus now the...
