Old 06-28-12, 11:51 PM   #1
Default A7 AirTap install (ASHP hot water heater)
Here's the links:
AirGenerate
http://airgenerate.xbitech.com/Media...ion_Manual.pdf
Web links?
An Affordable Heat-Pump Water-Heater Retrofit- GreenSource Magazine
Airgenerate_AirTap_Installation_Upgreen Store - YouTube
http://411plumb.com/airgenerate-a7-airtap-review/
Specifications: (Ambient Temp. 68˚F)
Max Water Temp: 130˚F
Energy Factor 2.2
1st Hour Rating (40 gal tank): 44.5 Gallons
Output kW 6.5 kW (Hybrid average)
Dimensions 18" x 14" x 14" (height)
Weight 50 lbs
Noise 50 db
AirTap™ Installation Requirements
Volts 115
Amps 6 operating (12A start)
Phase 1
Frequency 60 Hz
Space (ventilated or ducted) 250 cubic feet
Space (unventilated) 1,000 cubic feet
The goal is to discontinue burning oil for hot water and use the A7 AirTap ASHP.
Step 1. Will be product testing (as described in the manual), hopefully this weekend.
I'll post my findings and some pictures.
Step 2. Select the size and shape of the hotwater storage tank (aka electric hotwater heater), and order it.
Step 3. Install the hardware, when the tank is delivered.
Here's a block diagram of the new system.
The Following 2 Users Say Thank You to Xringer For This Useful Post:
FortyTwo (07-01-12), Ryland (06-29-12)
