Yeah, the panels aren't the highest quality out there, but they will definitely get the job done, and of course the price is right! We just have to find a good way to refurbish the rest of the panels.
Ben, I was thinking about the panels a bit more last night. We were talking about using C channel for side pieces. We don't have to use one long piece. We could cut out right around where the header pipes stick out and replace just that small area with C channel or re-bent aluminum sheet. We would just screw the C channel to the sheet aluminum frame. This would allow us to use whatever end connections we want since we could drop the collector straight down.
