Old 07-17-17, 04:29 AM   #65
spiritofscouse
Default re washing machine to toilet flushing
Hello what filtration are you using?
Im thinking of using sand and gravel filtration together with mesh .
Did you do anything for the odour? Attached is my planned set up.
Originally Posted by bennelson View Post
I can't believe the filter clogged up already!
I have had the graywater system running for less than a day, when the pump started running without stop.
I checked the pressure guage, and sure enough, the gauge was LOW, and the pump was cranking away.
I pulled the filter cartridge out, and it did look all linted up.
Mostly, I just was too keep anything from going through that will gunk up my pressure tank, shut off valve, or toilet valve.
I put the filter unit back together, WITHOUT, the actual filter, and everything runs great again!
Maybe I just need to replace the stock filter with a course one so that it only filters out the big stuff.
spiritofscouse is offline   Reply With Quote
