An interesting paper, it almost read as if he was discarding R410A because if its high GWP - interesting that it now seems to be the refrigerant of choice in mini splits.
Another interesting point was (for another thread!) the mention of automotive air conditioners being modified to run on propane - anyone know how this is done? Acuario |
I don't know of anyone using R290 in a newer vehicle that was designed for R134A but I suppose it would work. I did read of someone blending R290 into a working R134A system. There is a research paper on the web describing R290/R134A blends. IIRC, the goal was improved oil transport and the ability to use mineral oil instead of synthetic. I am currently weighing the benefits of dual compressors against an automotive compressor and inverter drive. Automotive compressors are certainly durable. I'm not sure how poorly they compare with hermetic pumps for efficiency. |
So, I think that the choice of R410a is related to the profit to be made from a patented refrigerant. How else can the headlong rush over the global warming cliff be explained? -AC |
The super-kool, frosty-freez, amped up automotive recharge cans sold in auto parts stores everywhere are basically R134a with varying amounts of R290, R170, and R600a blended in. The higher the performance level, the more the R134 is tainted with hydrocarbons. BOC/Linde has Care 30, a blend of butane and propane, blended for R134 systems.
Pressure - Temperature Graphs...
For what it may be worth, here are some Pressure Temperature Graphs for some HC gases (also Ammonia) that have been used as refrigerants:
http://encyclopedia.airliquide.com/i...r_Pressure.GIF PROPANE (C3H8) P-T GRAPH http://encyclopedia.airliquide.com/i...r_Pressure.GIF BUTANE (C4H10) P-T GRAPH http://encyclopedia.airliquide.com/i...r_Pressure.GIF ISO-BUTANE (C4H10) P-T GRAPH http://encyclopedia.airliquide.com/i...r_Pressure.GIF PROPYLENE (C3H6) P-T GRAPH http://encyclopedia.airliquide.com/i...r_Pressure.GIF AMMONIA (NH4) P-T GRAPH Best, -AC |
Stirling Idea
Here is a pretty cool Stirling Engine project.
Stirling Engine SV2 MKII by Kirk Engines, Inc. - YouTube -AC |
hcr-188-c
1 Attachment(s)
Are you sure you're not a Jedi master? This HCR-188-C line looks REALLY GOOD as a next-generation solution to the current ozone depleters and greenhouse gas refrigerants. The C1 formula has already been approved as a substitute for R-134a, and looks to perform better at higher temperatures. http://ecorenovator.org/forum/attach...festo-0001-jpg http://ecorenovator.org/forum/attach...4&d=1458005597 Adding to the sweetness, Mr. Maruya (and his trust) is in the approval process for the C2 formula. Designated as R-443a, it does its job in the R-22 range. http://ecorenovator.org/forum/attach...file-page1-jpg |
Stirling engine refrigerator
Award-Winning Product Development
http://stirlingultracold.com/lib/sit...-isber-big.jpg In January 2013, after significant beta testing at customer sites across the US, Stirling Ultracold introduced the Model SU780U to fulfill a market demand for a large (27.5 cu.ft.) upright ultra-low freezer to replace conventional cascade freezers. Successful deployment of the SU780U and independent customer performance testing generated critical praise from biorepository and pharmaceutical experts worldwide. In May 2013, Stirling Ultracold received the International Society for Biological and Environmental Repositories’ (ISBER’s) Outstanding New Product of the Year Award for its Model SU780U ultra-low temperature freezer. The award, given to one product annually, recognizes the company’s development and introduction of the world’s most energy efficient ultra-low temperature freezer, the Stirling Ultracold SU780U. http://stirlingultracold.com/lib/sit...story/M100.jpg M100 free-piston stirling engine carries a 7 year warranty Cools to -86 degC Uses helium as refrigerant |
I love my R290 its cheap, easy to use, and lets you know if you have a leak (lol).
But in my recent experience, 80% R1270, and 20% R290 worked amazingly well. Though I saw slightly higher amp draw from the compressor my COP jump .7 from just using plan R290. I have more data on this in the hot water heater build when I finally get the time to post again. |
