Search Forums
Search Results
User Name
Remember Me?
Password
Blog
60+ Home Energy Saving Tips
Recent Posts
Search
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Showing results 1 to 5 of 5
Search took
0.01
seconds.
Search:
Posts Made By:
AirConditioner
Forum:
Geothermal & Heat Pumps
02-08-20, 07:50 PM
10
Could a window A/C be more efficient than my heat pump?
8,061
Posted By
Ok so the dirt cheap twisty knob window units are...
Ok so the dirt cheap twisty knob window units are all over the place because they don't work too well. Nearly all of them have the lowest efficiency ratings ever. For your goals they don't have...
Forum:
01-29-20, 10:07 PM
10
8,061
Posted By
pinballlooking
Depending on the size of the rooms you actually...
Depending on the size of the rooms you actually use you could install a mini split in the bedroom you use. Then install a mini split in your main living room.
Mini splits in SC do a great job...
Forum:
04-22-15, 10:50 AM
25
Flat plate heat exchanger size?
18,444
Posted By
My thinking on my first system was exactly the...
My thinking on my first system was exactly the same as yours. But I realized along the way that I would need to join copper tubing. I had all the equipment and supplies, propane torch, flux, solder,...
Forum:
04-21-15, 08:19 PM
25
18,444
Posted By
NiHaoMike
You might want to consider a "coax coil"...
You might want to consider a "coax coil" exchanger. It's nowhere as compact but the bigger internal volume makes it a lot easier to get the charge right. If possible, get one with about twice the...
Forum:
04-21-15, 12:29 PM
25
18,444
Posted By
Welcome to hell... (just kidding) This is a...
This is a great project that you want to do, and I hope that you completely succeed, and that your share your success (and errors/mishaps) with us through...
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forum News & Feedback
Introductions
Improvements
Conservation
Lawn and Garden
Appliances & Gadgets
Tools
Lighting
Renovations & New Construction
Solar Heating
Solar Power
Wind Power
Biofuels
Energy Storage
Other Improvements
Product Reviews
EcoRenovator Blog Discussion
Off Topic
The Billiards Room
For Sale / Trade / Wanted / Web Finds
09:22 AM
-- Green
---- Test Green
-- Blue VB
Contact Us
EcoRenovator.org
Archive
Top
Ad Management by
RedTyger
Inactive Reminders By
Icora
Web Design
