Old 06-01-16, 11:00 AM   #77
mejunkhound
Have most of turbine welded up (pic), need to get the bearing supports welded up next, etc.
Grandsons did some of the welding, lots of technique for them to learn yet.
I'll let them drag the 200 ft of sch 80 surplus pvc conduit thru the woods for the penstock, will try to remember to take pic of that when we install
the old chevy 2.8L flywheel gear will drive a starter pinion and the generator at about 4000 RPM.
it.
I forget how to insert an image without having it on the web ? Name:  DSCN7531.JPG
The Following User Says Thank You to mejunkhound For This Useful Post:
ecomodded (10-25-17)
